with this file
with this file
i tried the orginal bios from backup and the laptop is working but the same error ,manufacting mode active.The error log showing its service tag error,there is no service tag.Please repair me the orginal backup with the service tagSO I FIND THE RESISTOR ITS 100OHM
So i find the cap.It was 100ohm Resistor.the laptop turned on but no lcd and nop fan.Only keyboard backlight and dell logoapears.Then i try the new BIOS flash and the laptop dead.So this BIOS maybe not compatible.Please help me.here i am uploded the original BIOS backup.
with this orginal backup the laptop is working but as same the manufacturin mode active and there is no service tag.the error apears for the service tag.please help me to fix the servce tag.SO I FIND THE RESISTOR ITS 100OHM
this file working with service tag and everything fine but the issue is not recognizing hard disk.Maybe another file will work.
hard disk problem can't be solve with new biosthis file working with service tag and everything fine but the issue is not recognizing hard disk.Maybe another file will work.![]()
very good to knowfind this one in google search and worked perfectly.Solved
shobdoo , Salimeh Bolboli , Mbaruku kikungo , igiteam , TheT1ed0 , SSV , valkn9797 , itec1978 , Vahab Hemmati , zirla , Kanini Technology , jiffan123 , Yoseph G , banofils , user57871 , Sketch123 , COM22222 , Jarek Papierz , DrElettronica , Admin
