How To Unlock Bios Password HP Probook & Elite Books
Founder
SUPPORTED MODELS
HP 6550B, HP 2530P, HP 6930P, HP 8530W, HP 8460P, HP 6460B, HP 2230S, HP 6455B, HP 2730P, HP 8530P, HP 2740P, HP 4310S, HP s4510, HP 6535B, HP 6730B, HP 6735B, HP 8730W, HP 2560P, HP 8560P, HP 8440P, HP 8540W, HP 8560W
If your model is not listed you may experiment with the 'Make All' or SHOTGUN.
USE
To use this system, select your supported HP probook/elite book model from the drop-down list. The Serial Number field and UUID Filed will need
to be populated with data. This data needs to be that of your own laptops. Booting to this thumb drive (if this package was created from official .img)
will obtain this information automatically and can be imported.
Once data is entered/imported into the fields, click the 'make key' or 'Make All' button and a file will be created in the /output folder.
You may then reboot to this thumb drive and CD to 'output' and run your exe file, or CD to '\output\all'and run shotgun.bat
ABOUT
Displays this information
IMPORT
Booting to this USB Drive will collect information about your and save it to file.Clicking 'Import' will read the information and fill out the fields automatically.
If you have not booted this thumb rive, there will be nothing to import.
MAKE ALL
is your model not on the list? Use the 'Make All' button to create all possible keys Using your UUID and SN. This will output them to the '\output\all' directory.
This will also create shotgun.bat file. Boot to this thumb drive and CD to '\output\all\.Run shotgun.bat.
MAKE KEY
this makes a single Key based on your SN and UUID for the selected Model. File will be created in the '\output' folder.
Reboot to this thumb drive and CD to '\output' and run your exe file.
LOCKED BOOT ORDER
If your BIOS has a locked set boot order, and will only boot to HDD, you need to take a laptop sata drive and use an external adapter and
make it dos bootable on another host machine also placing the files on this drive, then replace the internal hdd with your created dos boot-able HDD. Powering on the machine will boot to the dos environment. Using DOS commands, navigate to your files and execute them following directions on screen. BIOS will be free of passwords, TPM will be cleared.
DISCLAIMER
There may be unforeseen negative results stemming from use of this system. By downloading and using my tools, you agree to use them at
your own risk. This was originally for me, but I have opened up to the community. I am not a professional programmer. There is no
guarantee of success using this tool, even on units that are marked as 'confirmed'.
Along with this tutorial video , you can download the software which you need to reset password of Hp probook /Elite book.
  • HP_BIOS_P_word_Reset_EN.zip
Users who has read this topic
pankajbiyani , nassarraouf , Copper Lines Infotech , user57416 , Umut92 , gayan123 , Madonaq , user60380 , user57739 , shobdoo , , vicsem73 , , Cyberlero , , , , paulojarasantibanez , phantom2002 , , user27703 , user39082 , sarphones , Micro-computers , , sultan321 , user27015 , CZ027 , marufpatowary , Yousuf , user6702 , user60406 , kh2022 , user48130 , user60391 , CRCM , jeremyadams , MEHMET BAKAN , 14Darkmotives , babalsalama , suton , samemuro , zinmina , user45048 , AB WALI , user18370 , user61654 , user57880 , Almoheet , ABCDELAMICROELECTRONICA , Austyboy20 , sware , TR556 , jands98 , user6389 , Trigen89 , user61858 , Cucuk Sugiarto , Dlspro , Wilson Caduyac , user5821 , DarkRiderPR , user46647 , luoyanchun , cqdly , kimta , Paddybo , DrDom , boubou26 , user7902 , OZAY KORKMAZ , model-computer , Khushi , cihan , LAEngineeringElectronics , akaeyes , gajanan1987 , fatihtok , rt1234 , h00jad , eddouille , chellbee , francisesgo , userzxc , Cyberlero 3 , joel124345231 , compu2000reu , azertn , rv2022 , copciller75 , Lazerthomas , tommy , nozerorma , Damas , innocentdon505 , ikmenin , deebread2023 , user47831 , gullu , mrkktw , hosam21 , Waldek88 , ITWORLDDZ , TomTindall , johnson2165 , Electronica360 , aaho , CTS1983 , Prozon , arfarf , Silent73 , cmmm , user30915 , GlitchFix , Shafiyudeen , user54196 , boki , user26471 , rajuveeravalli , kysh , rocky971 , techcentral , vildanasuta , Canaan , banofils , APGUS , nimoemoo , user30692 , user55973 , BAB AL HASOOB , LowVoltage , PeterPan , user40254 , Willie , AnIK2k23 , user50969 , user37894 , bilalinfotex , Sloth73 , alfredposadas09 , destinycenter , alirezakwww , user3333 , Younoussa , Ahmedraheem , franco escobar , user57871 , Scuderia , PunchFalco , BeOneIT , Hughs78 , Nassim I , cupsmaniak , fitzgeraldnolos , irepairs , Ant-mal , jimmyburgin , Max Sand , Pardon1984 , user51023 , user57573 , robase2023 , Aung Aung , isythica , Sezer1903 , sami2004 , GULSANKU , oswaldo mendez ramirez , kyhuu007 , Anknow99 , Nguyen Tuyen , mack2369 , Mike Gou , kendryleonidas1 , Dcomp , kishurik , mirekapx , ByrnetCom , bsitszerviz , Heizerfraktion , RichardJ , vlado-sv , kcjazdzi , Jozeph2174 , Edward2257 , Vladimir2128 , Yuska1960 , slickabs , M khalil , laststation , ichi , barracutie , dwalker615 , umar kha , janssonrip , emmanny1 , zman1302 , user13197 , vqcuong3007 , adamshut , Upendra1991 , jjo21631 , MIGUEL99 , Anomander , TuitamaNZ , waz000000 , Virgil z , michailgoldsmith , R K , mrzappajr , muhammad farooq , jbitservice , TokyoComputer , cosmokb4 , Bartosz007 , ERFANKHAN0011 , CyberleroJulio2024 , rixstaas , RangaDeo , Masadzala , abdulahi , dreifixph , Gabriel Tembo , teknikbilisim , akidimon2020 , ahmedabdelrhman , sentinelaeon , Lunik1999 , appleguys , Cyberlero2024 , MuckyMuck , guhan0001 , dory16225 , younes321 , MadMechanic , Ganturfive , user50220 , fawazdine , myrddann , juliamono , filippejsa , HpPrueba , Luis Pereira , cakoin76 , Elfantasma03 , jimghonum , deadline , HABIB KHAN , genachka , BADE3ALMOUG , Randrianiaina , gkumaran89 , dzgamer2000 , angrymilks , gamalm10 , Danminator , ColdLava , ninja1986 , jfgrijaldo , mihai vasile , mdssireparo , mady83333 , MoonRace , Minimee1234 , Test1234 , MisterBadr , Snyder Nc , serwisrnew , user15938 , Bluetail , tr4c3r2k6 , powerrider16 , deadlyprince , ghostDZ9 , user50851 , stanglobal , zeeshan sultan , bikobifa , roman0611 , bikobifaga , barcelonainformatica88 , bespoke22 , tgc202411 , Arce171717 , Zarachtout , f1b3r0ptik , rahma sued , krso3shmama , HQJaTu12 , beleksanka , German Cerna , fdgrhzjj6 , Empire Systems , labrd45benn29 , Turbo 57 , Marsfix44 , vincentKJ , Muntakayeash , ravenrocha , electrobank , user22354 , dz6g863a3 , racoon2k , vanoven14 , sr-saiet , user32163 , kweonjea , esght54r
